Posted By wes on 10/09/2009 6:34 AM
What happens if the ball isn't hot enough to go all the way through?
I seem to recall seeing this technique shown on a video on Youtube. That was the first question that came into mind. Assuming the ball does not stick to the foam I assume a strong magnet on a cord could be used to extract it. My question is, how can you be sure the hole will be centered in the panel? Too close to the skin and wiring may be damaged by nails/etc.
