Increasing exterior foam thickness
Last Post 26 Jun 2011 08:32 AM by
JohnyH
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
JohnyH
29 Mar 2011 07:31 AM
For those of you that have built ICF to the rafters in a predominately home heating climate (Ottawa, ON. Canada) has anyone or would you recommend increasing the exterior foam thickness?
John
lightfire
25 Jun 2011 06:35 PM
interested in this answer as well.
slowroadster
25 Jun 2011 07:29 PM
Ditto
BrucePolycrete
25 Jun 2011 10:08 PM
You can increase the foam thickness if you want, and you will find a million opinions here. Bottom line is it will save you a few pennnies but some will tell you it's not worth the effort since it limits your choice in brands and may cause complications.
Fire&Water
26 Jun 2011 07:03 AM
You can add EIFS (Exterior Insulation Finish Systems) on the outside, I believe upto 10" or 12". Your R-value will be significant. You will be limited to a stucco finish
a design analysis and structural analysis need to be done to determine your breakeven point for the optimal foam thickness in relation to your inside conditions (=temperatures)
After a certain thickness the more foam has no payback and is kind of "useless"
Marc
Chris Johnson
26 Jun 2011 07:41 AM
In Europe the foam is thicker on the outside, you can order it that way in Canada from a manufacturer.
To add to an existing build the final cost savings (Energy) vs. cost to purchase and apply product is a big separation, so I am led to believe.
JohnyH
Thanks for the replies!
John
Membership:
HotnCold
People Online:
