Green/Energy-Efficient Design and Planning
Adjusting hyper heat mini split temperature controls
Last Post 09 Dec 2015 09:01 PM by
Toadman
. 8 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Toadman
23 Nov 2015 08:02 PM
I spoke to a company that sold mini splits. They said there is a way to program the the temperature difference up to 5 degrees on a 18000 hyper heat so it doesn't ramp up as quick. Does anyone know how? I looked at my link drive and didn't find it. I was told it was on that site
24 Nov 2015 12:29 PM
I don't know, but there may be a market for an add-on mini-split thermostat that is highly programmable. Would probably have to interface to the existing mini-split thermostat via infra-red or RF.
For example, what if one wants to use a mini-split for heating when it's mild outside and an existing NG furnace when it's really cold (such a plan could optimize $/BTU).
https://community.nest.com/ideas/2149
Toadman
24 Nov 2015 12:30 PM
Spoke to the rep again and he said I could adjust the temperature differential in the unit. I've been searching and couldn't find anything. Do these units have that kind of option because It be nice.
Toadman
24 Nov 2015 04:01 PM
I was looking to get a price quote on the thermostat but he said to adJust the The temperature differential first to see if that helps. Im all electric here.
pbrane
24 Nov 2015 10:22 PM
What kind of unit do you have? I just figured out how to do that on my Fujitsu....... -m
Toadman
24 Nov 2015 11:41 PM
I want to do it to a fe18na hyper heat wall mount I can't find anything.
Toadman
24 Nov 2015 11:42 PM
It's a Mitsubishi. Forgot the brand.
Toadman
25 Nov 2015 11:35 AM
I called another company that sells/tech support and asked about it and I was told there isn't a setting on the unit. I'll prob have to get the thermostat. Does anyone know the minimum heat temperature that the unit blows out? 108 seems to hot for the minimum 7500 btus it puts out.
Toadman
Just decided to get the mk1 thermostat. The unit is short cycling again. At least this thermostat can be away from the unit where the temperature doesn't fluctuate to much like near the ceiling.
Deadband question. If the unit has a 4 degree deadband and set at 70, will the unit ramp Down or continue to 72 and ramp down before it hits 73?
Membership:
hudson2000
People Online:
