Posted By Ohio_alternative on 10/11/2007 9:47 AM
Can i use the trench or hole for a deep well
when its filled in , after being dug ? Thinking of using stone as a
filler ?
Not sure what you are asking here. Do you want to run a well out of the same hole as your geothermal pipe? This will not work. Where do you want to put the stone? Around the geothermal pipes? This is not a good idea either.
Most geothermal pipe companies offer a 50 year warranty on the pipe. As long as the system is installed and tested properly, it will last you a long time. Most of the loops problems that I have seen come from the pipe having been damaged by digging or trenching . No policy will cover someone damaging the pipe.
