<!--[if gte mso 9]>
I am juggling a few
different heating scenarios and am not sure exactly what to do.
We are purchasing a house (primary residence) in 2 months. The previous
owners had enormous dogs which destroyed the flooring, with piss I
imagine. The floors were ripped up and the entire first floor is stripped
down to the slab. Yup. No basement. One big cold slab.
So, here I have a fresh palette to work with (if you don't mind the lingering
stink of Big Dog pee).
The house is 30 years old, 2300 sq feet, gets a lot of southern exposure, and
has hydronic baseboard (again, dog pee has rusted the radiator covers pretty
good – who were these people, I mean, really?). The oil furnace is
kaput, btw.
So here are my options:
Option A: Electric radiant with a wood stove and engineered hardwood floors/
tile:
(Cutting out the baseboard)
The Positive:
- I can zone every
room. By installing a wood stove in the center of the house, all the
other rooms will accommodate the movement of heat (turning on at the margins
where the wood heat is not reaching) Some zones would not need to go on at
all. Every room could be a minimum of 70 degrees.
-Repairs can be
localized
-If the apocalypse happened,
I have the wood stove to heat the house, albeit not ideally.
The Negative:
Electric is not a good
selling point for resale.
Electric Bills can be super high.
Whole-house electric
radiant is not heard of. All my
contractor friends think I am nuts. “Keep it in the kitchens and bathrooms”
they say. “You are a jerk” I say…. I have less contractor friends now than I
used to.
Option B: Hydronic
Radiant with an outdoor wood furnace/ oil furnace backup.
(Converting the
baseboard to hydronic radiant).
The Positive:
-Energy independence. I have a lot of wood on the property.
-Cleaner that putting a
wood stove in the house
The negative.
-I can’t control the
zones. The first floor is going to heat
however it does. If one area is too hot
or cold, well tough. That’s the way it is. No adjusting.
-Feeding the furnace is
a lot of work.
-Having to pour more new concrete
for hydronic than electric (thicker tubes)
-A leak could be disastrous.
-If the apocalypse happened, I
can’t run the circulator (no electricity) and am up shit’s creek. It could happen... you laugh now.....
As I am writing, it seems to me
that the electric might be the best bet. But I’m no engineer or mathemagician.
How well does radiant heat go
through engineered hardwood?
I don’t know the answers and don’t
have any good insight here…
Is this all just stupid? Should I just get a new high efficiency oil
furnace and clean up the baseboards and stick with what I have?
My head hurts.
<!--[if gte mso 9]>
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
